2014 Ford Fiesta SE cranls but won't start
Fate
TX
2014 Ford Fiesta SE
Having an issue getting this Fiesta to start. I replaced the waterpump as it went bad and now the car won't start.
Battery is good, replaced fuses and relays for starter and fuel. Replaced camshaft pressure sensor, crankshaft pressure sensor. Have spark to plugs and fuel flowing(fuel pump engaging and has power). Reset the ECU by draining and resetting. Compression seems good.
Car was starting before the waterpump install. At a loss as to what to try next, any help would be appreciated.
Check for passive anti theft module response. Can you activate and disarm it?
It smells like a pats fault.
When you have spark yet no fire - you sure you have the timing correct? IF it's off 180 degrees - it could backfire.
So kinda wondering how you'd see spark yet no engine firing up or even a backfire.
