- Southwold
- Non-US
- Canada
- 2015 Ford Focus SE
2015 Focus SE 2.0 flex fuel
I was in the process of changing out / upgrading the head unit ( radio/screen) when everything went crazy when the battery voltage dropped too low and the car had a hissy fit. Not sure if it was something I did or the voltage drop but the front wipers stopped working even after I returned everything back to factory parts
these are the codes it is throwing and additional details
BdyCm: B101E:23 <<---Air Conditioning Mode Switch -Signal Stuck Low
B1089:23 <<---- Blower Control -Signal Stuck Low
B1131:87-2F <<<-----windshield wiper motor communication failure (specifically a missing or corrupted LIN bus message/signal between the Body Control Module and the wiper motor)
does anyone know the location of both ends of the LINbus Wire ( I believe to be gray with violet or purple strip ) go to (what conector where and what pin numbers i should check and test??
the photos are of my bcm for reference and I do have Forscan as well as the ODBII adaptor so I should be able to make changes and adjustments
Any info would help
sorry forgot info from Forscan
===BdyCM DTC B1131:87-2F===
Code: B1131 - Wiper motor module
Additional Fault Symptom
87):
- Missing Message
Status (-2F):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Body Control Module
Freeze Frame #1:
-EVENT_TIME: 357156618 s (Thu Sep 03 10:30:34 2026) - Event time
-TOTAL_DISTANCE: 119762 km - Total Distance
-MODULE_VOLTAGE: 11.5 V - Control Module Voltage
-PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
-PWR_MODE_KEY: Ignition On - Power Mode Key State
===END BdyCM DTC B1131:87-2F===
Any info would help
- Missing Message
Status (-2F):
Freeze Frame #1:
