Blue lamp identification
Hi I'm new here, and hope I'm posting in the proper spot. My daughter just bough an 01 Focus. It seems to be a great little car. In getting it ready for her, I came accross a blue lamp under the dash, near the hood release and fuse panel. It has two rather long leads, one red and one blue. It seems to be always on, 24/7. Please let me know what this is and where it should mount. Thanks for any help.
That's definitely not stock. Does the car have an aftermarket alarm?
R
Thanks for the response. The only previous owner says she doesn't know of any aftermarket add-ons of any kind. I kinda wonder if someone was using it as a test light and forgot it. I've discovered that it does eventaully go off, but not until much later than the dome/courtesy lights dim following door close. It stays on after those go out for at least several minutes. If you're certain it isn't stock, I guess I'll try to trace it back to a source and disconnect it.
If you can't trace it to anything just disconnected while its in the garage to see if it affects anything. Take a picture with a cell phone before you do so that you can reference where it plugs into.
