Transmission
pcline55
I don't know if I am in the right thread but here goes. I have a 2012 Focus SEL and the transmission is messed up really bad. I recently took it to the Ford dealership and they said I need a Clutch Assembly, TCM and input shaft seal all for 2000. My question is would it be cheaper to buy another transmission off ebay or somewhere else and have it installed? Can I use a 2014 transmission and what all comes with another transmission? Thank you!!
Administrator
You'll be taking a gamble purchasing another used transmission. Probably be better and cheaper to fix what is broken.
pcline55
So I should let the Ford Dealership fix it or another transmission shop? That's just a lot of money for me that I just don't have. They have fixed all this before and I am scared it will tear up again.
Same thing happened to my clutch on my 2014 se. Just replacing the clutch is really the only way to go unfortunately however mine lasted for around 100000 mi. So it's a fairly good fix in my opinion. I have 23000 on my new one and its running perfectly!
