- Not-US
- Non-US
- Canada
- 2011 Fiesta SE
Welcome to JPs General Tech on Car Wash Soap!
Refer to my JP's General Tech Introduction to Detailing 101 for more information on basic detailing tools and items.
Soap...Mix it with water, make suds, remove dirt...Seems pretty basic. However a proper Car Wash Soap is very important to keeping your paint looking good. Also equally important are all the other items on your car that need a proper soap such as plastics, lights, rubber, chrome etc. Choosing the proper cleaning agent for your regular washes will help to keep your car clean. Choosing the proper cleaning agent when you have a quality wax or sealer is exponentially important. You can easily undo protection by using the wrong cleaner.
First, What is the purpose of using a soap in car washing? The ideal soap when washing your car will lubricate the surface of your paint. This is arguably the most important role when washing your car. You can wash your car with almost any product, but none of those products would be up to the task. Your cleaning agent must be able to lubricate the surface reducing damage to your paint. This is why many proper automotive washes feel slippery and are loaded with foaming agents giving copious suds. The slickness of the soap and the foam will work together to "float" away dirt as it slides down the car. Also not to be reduced, the soap must be able to break the surface friction where the dirt is attached to the surface. This will reduce scrubbing, which would lead to more scratches. This will be accomplished by a host of chemicals and oils designed to break down dirt, clean the surface and encapsulate any abrasives. Finally, the soap needs to wash away clean without leaving a residue. This would not only immediately affect the shine, but as the sun bakes away at the residue it would do all kinds of nasty to your paint. Cleaners specific to washing automobiles will be properly pH balanced as acidic and base solution will have adverse effects on the surface of the paint.
One common product people will use is a Dish Liquid to wash their car. It may be cheap, hell it may be handy, but it should never be used as a part of your regular wash regiment. Dish detergents contain stabilizing and thickening agents, surfactants, salts, fragrances, dyes, and preservatives. The combination of these ingredients creates a higher pH level – usually in the 8.5 to 9.5 range. This is what helps to remove grease and food that is caked onto plates and dishes. In the kitchen sink, you don't need to be worried about soap degrading the surface of your stainless pots, or stoneware dishes.
***If you are planning on stripping old coatings a Dish Detergent can be used, however there are properly formulated stripper solutions also available.***
I would advise to look for a product that does not include a wax. Duo wash products apply the wax to the complete vehicle. Your wax should be applied to the painted surfaces where it is needed. The wax over time can build up on plastics adding to the problem where trim oxidizes and begins to appear chalky.
I have been using Meguires Gold Class for a long time now and have never had an issue with the product. pH neutral, safe on waxes and sealants. It foams well, my wash mitt glides easily even over heavy build up such as behind wheel openings and it rinses away spotless. Gold Class has very good market coverage and is easy to find and is relatively inexpensive.
Chemical Guys MrPink has been well reviewed by many. It is a high foam action cleaner, pH neutral and formulated for weekly use. Safe on waxes & sealants, and can be used in a bucket wash ("2 Bucket"
) or with a foam cannon. This stuff is great, and in a foam cannon is actually a lot of fun.
I used Zymol AutoWash long before I fell down the detailing rabbit hole. Suggested by a friend while he washed his YZF one day. This stuff foams good and the foam hangs around a long time. I switched to Zymol from wash and wax I was using as a top up to my low rent wax...how times have changed.
I have had good results with many of their products and the next time I put an order in I will grab a bottle of Poorboy's Super Slick & Suds to test out.
Waterless Wash - I still like my old school bath time procedures when washing a car. The "waterless wash" is an alternative to digging out all the kit. With so designated products and a microfiber towel, you can clean light dust and dirt from your car. I would consider using this in emergencies such as large bug impacts or bird droppings if they were recent. Not only does it clean, but many of the products will protect the area by applying a wax or sealer coating at the same time.
Thank you,
JP
edited for updates
Thank you,
JP
edited for updates
