Newby questions...
SteveK
Have had my 15' ST a few months and love it but a couple questions. Bought it from a Ford dealer and did the test drive but with the salesman with me and the neighborhood we were in I couldn't really open it up. But drives perfect. Had it delivered and once I got it out on the highway, it has a blow off valve which does sound cool, no problem. So can one just install an upgrade on the blow off valve or does it have to be with a larger turbo only? It pulls strong but I can't compare it to a stock one.
It was also lowered with H&R springs but it doesn't make U-turns so great. Is that because of the lowering springs? Thanks y'all...
Manchester
Ford Focus
Sounds like you’ve got a great ride! Let’s break it down:
Blow-off Valve
You can definitely upgrade the blow-off valve (BOV) without upgrading the turbo. Many enthusiasts do this for better sound, durability, and quicker response. An aftermarket BOV can help even with a stock turbo, though it won’t necessarily add power—just refine the driving experience. If you plan to upgrade the turbo in the future, look for a BOV compatible with both setups to save money down the line.
Lowering Springs and U-Turns
The H&R lowering springs are likely the culprit for the reduced U-turn performance. Lowering a car often reduces suspension travel and changes the steering geometry, which can make tight maneuvers trickier. If it’s a big issue, you might consider adjustable coilovers to fine-tune the setup or upgrade the sway bars for better balance.
If you're ever looking for more Focus ST upgrades or even considering a new one, check out Focustogo! It's a UK-based marketplace specifically for buying and selling Ford Focus cars, including ST models. You might find some great deals or connect with other Focus enthusiasts.
Hope that helps! Enjoy your ride. 🚗💨
pompeyrodney New Member Introduction 1
L Focus ST 8
ChaosXIII First Generation Focus 8
