2013 Ford Fusion 1.6 engine trouble
KoolAl
Huntsville
AL
2013 Fusion SE
This is all after i did a headgasket job on my fusion. The engine started running smoothly, with no issues. The timing is good after fixing the p0016 code for cam/crank correlation. While letting it run, the afr were looking good. Then, all of a sudden, camshaft codes popped up for both sides p0340 0344 0365 0369. Check the volts on both pigtails, ground 12.7v, signal wire 4.8v), and power 5v. I did the metal test for the camshaft, and the volts didn't drop like it was mentioned once touching the tip of the cam sensor in a forum I read, also on a YouTube video. All of a sudden, those codes disappeared, and now I have a po0c6 for low pressure in fuel rail. Car will crank and turn over just to die out. Yesterday, I drove the car for an hour, and no issues were cranked on point. Then this morning, it was like something else decided it didn't want to work.
Sent from my SM-F926U using Tapatalk
