 - Victorville
 - CA
 - United States
 - 2006 Ranger
P0316, P0306, P2272
- Montanomo Bay
 - Forums
 - Gallery
 - New Posts
 - Subscriptions
 - Messages 0
 - Log Out
 - View Full Site
 - Advertising
 - Cookie Policy
 - Privacy Statement
 - Terms of Service
	P0316, P0306, P2272
Subscribed
Montanomo Bay , 1 Minute Ago
Hello, I have a 2006 3.0 that has a nagging misfire and o2 sensor problem. I have done all of the following:
New plugs
New wires
New coil pack
New O2 sensor
New fuel filter
New injectors
Compression test: cyl 6 @ 105
The o2 sensor keeps causing a solid check engine light, even though it's new. I have a crack in my driver's side exhaust manifold, but not sure if this is causing the misfire as well. I'm going to swap it out after tomorrow. I will update on if this resolved P2272 issue.
Regarding the misfire, I just had the heads replaced about a year ago. I don't expect this to be the issue. Also, I've had some recent shenanigans with the crash detector switch cutting off fuel to the engine for no apparent reason. I just need to reset the switch when it happens, then I'm good to go. Otherwise, I have a random flashing cel, things get shakey, I lose power, then give it some gas and it comes back to normal.
After replacing all of the parts listed above, the truck runs GREAT!!! I just cannot shake these codes.
Please let me know if I can provide any additional info. I appreciate any help with this, thanks!
