- interlachen
- FL
- United States
- 2011 fiesta se 5spd
Hi there fellow enthusiast
So today i have a simple question for yall..
Which spark plug (brand,price range and material ) would you guys recommend ?
Now ,now I,m not talking heat range . The car puts out extra 17-20HP or 18% with current re map.( have yet to actually calculate that accordingly lol)
how ever here suddenly i went from 40 mpg to 37.9 mpg , haven't done anything different to the car or the way i drive ,other
than fixing the massive hole the muffler(J2 Engineering) had by replacing it with a Magnaflow one(so much quieter than i remember them to be).
These plugs are but a year old , Original OEMs Ford Motorcrafts (iridium) while I'm fully aware that when gas goes up quality goes down
so i been adding the xtra Octane Boost every other thank even tho i run 93 since November of last year , but i seem to be stuck at that
MPG, i have an HUD to monitor everything and no DTC present other than the usual Small emission leak that pops at random and when so
clean the filler neck mouth and will go away for months at time .One customer of mine suggested to change them regardless being year old
simply because low quality gas will hurt the performance while not bad enough to cause a miss but clearly enough to suffer fuel economy.
Wondering if i should just stick with OEMS or maybe venture a different brand
Been Thinking Denso TTs , NGK Yitrium or Iridium
I have always been a big believer that unless your are making 80hp over stock ,stick to OEM everything including manufacture heat range
just figured id take some suggestions/advice first and see what yall thoughts on the subject may be .
Thanks in Advance
Thanks in Advance
