Timing belt change interval?
Baytown
TX
2017 Ford Fiesta
I understand my 2017 Fiesta with the 1.6L I-4 has an "interference" engine. What is the recommended interval to change both the timing belt and serpentine belt? What is the cost of doing so? Can this be done by an independent mechanic shop, or is it necessary to bring it to the dealership? Thanks all.
According to the owner's manual, you should replace both every 150,000 miles. Any competent mechanic should be able to do it.
Cost of parts to do a timing belt replacement depends on if you choose O.E. parts or aftermarket. For this area, i prefer O.E. Ford parts. Because of the long maintenance interval of these components. I also would strongly recommend that you change the timing belt tensioner and the water pump! They are conveniently right there to be unbolted and replaced! This reduces the need to go back in later.
I dug out these images of the O.E. components. I installed them a little more than a year ago. I don't remember exactly what I paid. But it was not two hundred bucks. Maybe close. But I got it all. Including the tensioner bolt to retain the tensioner. Both made in Italy. The guy's recommend that we use red thread locker on that tensioner bolt! It absolutely must not come loose!
I thought that the timing belt was impressive. The cogs are coated with an extremely hard plastic coating for wear resistance. When you look at the aftermarket timing belt, does it have a coating like that? Betcha' it doesn't.
I couldn't find an image of the stretchy type serpentine belt. Probably forgot to back it up in the hard drive. 20210821_173341.jpg
G
Baytown
TX
2017 Ford Fiesta
Thank you. I won't stress on it until I hit 100K. I will do a major service at that point and that should take me to 200K. Both belts, tensioner, water pump. I am pretty sure I will go back to the dealer to get the OE parts. Hopefully I am fully safe until then. I service the car well and we don't beat on it. In fact its probably 80% highway easy miles on it, so there less stress on the components.
I will add one more "must replace" item. The coolant reservoir! There is a couple of threads in the maintenance and troubleshooting section. It's a genuine time bomb. If you don't know how old that reservoir is. Get rid of it ASAP. There is no convenient time for it to fail.
G
Baytown
TX
2017 Ford Fiesta
The reservoir is original, I bought the car in the fall of 2017 after I lost my two vehicles in the epic Harvey hurricane flood. (We had over 4 FEET of rain in five days...)
You must truly be a Scotsman, I noticed the tartan cloth in your pics!
There's the number for the Serpentine - that pic is from a set of photos I took when I first got my vehicle.
Lost a lot of them but I resurrected this from an earlier post.
N/A
Australia
Ford Fiesta sport Ecoboost 1.0
I believe the coolant reservoir was only an issue pre 2014,there was a recall on them.No issue believe from 2014 onwards,🦘🦘🦘🇦🇺🇦🇺🇦🇺
No. I have already replaced the tank on my 2016 ST. It's not a reliable component past three years of age. When they fail, it will not be in a convenient place or time. At around $40 retail, it is way cheaper to just replace it every three years than having to call a tow truck even once!
I am certain that neglecting this single part will put almost as many Fiesta's in the junkyard as crashes. Because overheating the engine is several thousand dollars of damage.
G
Baytown
TX
2017 Ford Fiesta
I believe the coolant reservoir was only an issue pre 2014,there was a recall on them. No issue believe from 2014 onwards,🦘🦘🦘🇦🇺🇦🇺🇦🇺
If there was a recall, and it ended in 2014, there must have been a change. Thanks for that info.
N/A
Australia
#14
The kit itself is not that expensive,it’s the labour cost that hikes the price up,very big job.Mine has 88,000kms on it,all is good.Changing your oil is one of the big things with these Ecoboosts,I do mine every six months,oil is cheap,a blown motor is not.The secret is not to let all the contaminates build up on the belt & internally in the motor.Good luck.🇦🇺🇦🇺🇦🇺🦘🦘🦘🦘
