2001 Ford Focus egr p0401
Dirt440
So I bought this car for 600 bucks and it had a bad shift solenoid a, fixed that no issues. Throws engine code p0402. Replaced egr, dpfe sensor, and the egr vacuum solenoid. Now that I replaced all that I'm throwing a p0401 code for insufficient exhaust recirculation. Problem after problem, any suggestions on where to look?
I had the same issue with mine and replacing the dpfe sensor fixed the problem. Just to be clear you did replace the egr valve right?
D
Dirt440
Yes, the valve and the vacuum operated solenoid that was connected to it
D
Dirt440
I haven't touched anything else on the car. I thought it was weird that it went from a excessive exhaust recirculation to insufficient exhaust recirculation
D
Dirt440
Ok, I'll have to do that after work. I was thinking that. Thanks guys
D
Dirt440
I could not find any leaks in the car, I'm not sure what's going on. Everything has its proper voltage, I haven't checked out what the evap test port does yet though
