Hello,
I have a 2013 Ford Focus, it will not start intermittently. It does not crank or attempt to start. All the devices will power up, but when you turn the key you can only hear a faint click in the engine bay area. The battery is less than a month old and we did try to jump it. Bypassed the starter relay, that works and it cranks. Swapped relays, still no start. Tried starting it in neutral vs park, no luck. I'm not sure where the starter is, although I think its below the airbox as the positive lead splits off and one goes down to where I can't see. I plan on removing those boxes when I get time to look around. I get the feeling its a common issue with this car.
